Rotor is removed using a 20mm x 1.5 pith bolt, Motion Pro sells it as a tool.
I know the timing magnet is good because it's intact. It'd have to loose magnetism to be bad. DO NOT remove those little screws on the outside of the rotor, those set the magnets inside into position.
You need a real FSM instead of the Clymer, PM sent
