Morning, anyone know where one can buy the sticker that goes onto the light cluster between gauges? The one that says, High beam, Left, Right, and Oil, and Neutral?
It wasn't there when purchased but need it for safety check. Thanks a million! Cheers, Ron
Discussion Starter · #2 ·
I believe it actually says Oil, High Beam, Parking Brake, Left signal, Right signal, and Ignition.
Until u find one. you might try a label maker. That should do the trick for safety. I'll look and see if I have one here as well. I'm in Winnipeg.
If not try the net. You may have to buy the whole assembly but there's no accounting for having too many parts. Try also Kijiji. Quebec's site seems to have them on occasion.
Hi Warren, Thanks, looks like maybe label maker, gonna look bush but it will pass the safety later this week :)
