Hey guys. Ran into an issue today where my brake light was always lit up. I had just finished replacing the back wheel so I figured it was the rear switch assembly. Took the switch apart and seen that I had continuity on the two leads even without them touching so must have been an issue with the front. (Unfortunately I destroyed the switch getting it apart and has to order a new one).
Went to check the fronts and noticed the front brake lever wasn’t going back enough after releasing the brake and it wasn’t closing the contacts and shutting off the light. Figured it was a simple adjustment needed and for out my Clymer manual and went at it.
After an hour or so of trying to adjust I just can’t get it right. It’s either too loose at the handle and doesn’t snap back to the starting position or it’s too tight and I can’t get the play that the manual says I needed (an inch or so if movement before the brakes apply). I’m worried that when it’s too tight the brakes will lock up way too easily but I can’t see any other way to adjust it properly.
Anyone run into this issue? Any pointers??
