Some of you may have seen my first thread, when I was (still) having troubles with the mechanical side of things. Decided to make a new one for another topic, as is the right thing to do. Anyhow, my CM400T came with a pre-destroyed ignition key switch up front, and better yet-- no key. Now I was about to go buy a new switch with the respective new keys but noticed that there are two other spots where a key is used: the seat lock and the steering lock. My question is, since I will be needing the original key, how do I get an ignition switch that matches? If I can find the original key ( I've heard searching the VIN or something) Should I just run a new switch with its own key and use the new original for the others? Probably sounds silly but I'm a little stuck on this. Thanks
