Hi Guys,
Would any of you know if i can use the Accel Super coil kit on my 79 cm 400t? It is .7 ohms not much more then stock. I have to re jet the carbs anyway as I've gone to pod filters and custom exhaust. I will get to that question once I start reassembly and ready to start. I have seen the post on the GM coil and would be willing to do if the Accel won't work. I'm trying to keep the bike as clean as possible and I think I can keep it in its stock location.
Yes, a .7 ohm coil will work fine. Be interesting to see if it will fit under the tank which the GM won't do.
Thanks, Jim. I'm hoping it will fit under the tank. I should receive it by Friday and report back.
