I have a 1978 Honda Hawk 400 twin that I’m working on for a friend.
When he let me at it, it would run and ride but it was low on power and barely made it to 35mph in first and would go basically nowhere in the other gears.
I took the carbs off and cleaned em up a bit, I found a clogged jet or two and the accelerator pump had the spring on the wrong side of the diaphragm so that wasn’t working at all. I put them together best I could with the same just a just cleaned out.
The bike runs good now but only for a minute or two. I started it up after putting the “brand spanking new” carbs on there and went to ride it around and it got to 70mph quite well but then after a little bit the bike would hardly accelerate even at full throttle, popped through the exhaust sometimes, and even died whenever I tried taking off, so a significant loss of power.
I have a feeling it’s a fuel supply issue but this is the first one of these style bikes that I’ve worked on so anything helps 😁
