Okay, my bike came in several boxes, and I'm trying to reassemble because the weather is getting warm.
I found the rear brake pedal return spring, but I can't figure out where the other end goes. One end hooks to the pedal, in the same hole as the stop light switch spring, but the other end looks like it's mounted either through a hole in the aluminum muffler/foot peg mount, or over the longer bolt that goes through that same aluminum bracket.
Any help would be greatly appreciated, is there a piece I'm missing or is it just old eyes?
Thanks!
Steve
The aluminum footpeg/swing arm bracket has a small hole at the bottom of it for the spring. Both the return and the switch spring use the same hole on the lever
Does anyone have a picture of how the spring sits in there? Ive spent the last 4 hours looking at the rear brake set up and I've totally ran into a brick wall. Any form of help would be greatly appreciated!
