Guys ... I've been rebuilding a '75 CB360T all winter and have the bike rebuilt, with the exception of the electrical system ... I have been studying the wiring diagrams (actually sometimes wondering if I am looking at the right one!) ... and am running into a couple of perplexing problems. I'll just start with the most intimidating one first ...
I bought a new Rectifier / Regulator from Rick's and have been trying to follow the instructions on wiring it .... I get the Red & Black leads as Positive & Negative respectively ... however, the other three leads are white ... when I disconnected the wiring harness, I marked each connection, that I disconnected with a number (ie. A-A, B-B, C-C, & so forth ...) ... I figured when I put it back together, I could just reconnect the letter / numbers to their corresponding match (which will still work mostly) ... as I look at the regulator, there are three wires coming from it ... black, green, and yellow ... my current assumption is that I should connect the three white wires from the new rectifier / regulator to the three wires the old regulator was plugged into ... is this correct? (See photos) View attachment 74247 View attachment 74248
That leads to my second problem ... my old rectifier is not stock ... and instead of having 4 wires (pink, green & yellow)coming from it ... there are only two yellow wires (which of course I tagged with corresponding numbers when I disconnected it ... there are also only two wires coming from the alternator, both black, that plug into the two yellow rectifier wires. (See photo)
Can someone please provide some guidance on this? Has anyone ever seen this before? I would really appreciate any advice you're willing to offer ...
