Hello everyone. I can’t get my neutral light to work. I have brand new gauges from DCC. I’ve replacements my wire harness. I checked the neutral sensor/switch and that’s good. I checked to make sure the neutral wire to the gauge is good. Still nothing.
Did you check the ground wire from the bar mounts to the gauge mount on the top bridge? It's a short wire that makes sure the bars are being grounded by something more substantial than the cables, as it connects the gauge mount to the bar mount to conduct a good ground to the bars from the frame by way of the neck bearings
Might be a bad bulb?
Have you tried applying power directly to the bulb with a 9V battery to see if it will light?
Generally the neutral wire light uses low-side signalling, so you want to make sure the neutral wire from the gauge is going to the light green/red wire in the harness. If your gauge has two wires for the neutral light, the positive wire will go to a black wire in the harness and the negative wire is the one that goes to the light green/red.
