I was wondering if anyone could give me info on the CB450 I got. I'm not sure of the specific model I know there are k's and other types. What kind of carbs? I'm new to these old metric bikes. Any info or tips would be appreciated! All the side cover says is CB450 DOHC. Was twin cam a S?
I hate to be bothersome, but it has a charging system malfunction, I need to move it, but there's no trailor. My question can I run it with no batt? I know some vehicles need the battery to complete the ignition circuit.
The stock bike has a battery ignition......Won't run without unless rewired a bit.....
Remove front fender and wheel, stick forks in your trunk and lash it in so it can "steer" behind the car...... Padding on car and a helper to lift it in usually required....
I have a Reese hitch extension I can bolt my axle through for similar situations.....
