First off, I searched to find an answer in the archives and found that all the posts led me to more questions. Also, I have the Honda shop manual and the Clymer manual. In the Clymer, it suggests using a "hotter" plug if the engine is not serviced. I cannot afford any parts right now, but I can't afford dieing right now a bit more :lol:
I smelled the oil, it seems fine. But, I don't know for sure. I rode for about 1hr, and the bike had some gray smoke when I was stopped at a traffic light. The left plug was kind of fouled, but not too bad, and not really wet...more on the sooty side. Oh, one thing I forgot to mention, the right exhaust pipe is kinda getting golden, the left is perfect chrome, I guess that is due to not working properly?
If the pipe is "yellowing" then that suggests that side is running lean. Or the valves on that side are out of adjustment/worn. Could be a timing issue as well. A complete carb teardown/cleaning may be in order as well..
Have you performed a compression check yet? If not then that's probably the first thing that should be on your to do list.
You didn't mention where the grey smoke was coming from..?
When I first got the bike I did a carb bath/rebuild so I know the carbs are fine.I checked the spark plug on the "golden side"(right) and it looks perfect. The golden color was like that when I got it. I was just trying to give as much info as possible to help figure out the problem with the left side, but I guess it wasn't needed... The gray smoke is coming from the left exhaust. Still haven't got a compression gauge. I hoping I can use the one at my local shop.
The smoke may just be unburnt fuel. I had that problem at one time when one cylinder was running intermittently. It was blowing greyish smoke too..
You NEED to get compression readings........
Right compression test, I'll get it done.
