Hello all. I’ve posted this to another board as well, but it seems like this one is just as active, so...I figure it can’t hurt to take as much advice as possible.
About me: I’m a small engine repair guy. Not too many months ago my wife became seriously ill. My side gig is as a musician, and she was no longer able to play. We were a duet act...so I started looking for something to do. Being busy is good for you. In my hoard I had a ‘73 CL350 that I kept coming back to. I can repair an engine, but to be honest I don’t do much aesthetic work, or restoral. Never too late to do something new. Most of the things that I work on are purpose-driven machines, with the occasional four wheeler suspension repair or carb tune-up on a motorcycle. Still. I wanted to fix that bike, and just before one of her hospitalizations I told her we would most definitely ride this thing.
The bike: It was originally partly in a box. I should have thought to take pictures of it, but I wasn’t sure where I was going with it at the time. The carbs were off and packed with an amazing amount of carbon residue. It had one cracked cooling fin and one bent. The originally forks were bent badly, and the factory battery and airbox were zip-tied to the frame. The gas tank had a half-inch of sludge in the bottom and the petcock had actually dissolved. No spark, no fuel, no air. The seat was a glob of mildewed foam with the brackets rusted and bent. The headlight bulb was cracked open and the wiring just...destroyed. It last ran in 89 and was backed over by a bad driver at some point.
What I have done so far: rebuilt the transmission, picked up some used forks, replaced the points, wires, condenser, ignition coils, starter solenoid, fuel lines, front steering bearings, rebuilt the wiring harness, ignition switch, wrapped the exhaust and put in new gaskets, cleaned the oil filter, checked the valves, soaked the head for a bit in Marvel and crooned late 60’s studio pop to it. Maybe not that last part. I have played around with the application of different varieties of paints and posture for it, and I generally try to cover at least one item a day. I experimented with a GSXR front end and wound up not liking it and wiring-brushing rusty forks. Today I sealed the tank and hooked up the carbs.
Still to do: The bike was in the mud for some time. The spokes are rusty beyond words and will need replacing. I need proper switches for the handlebars, and I wouldn’t mind running the wiring through the bars. I need to run an exterior rethreader around the mounting posts for the rear shocks and finish the exhaust. Two tires, a new chain, speedo-o and tach mounted...I’ll need to fab something for that. I need lights front and back and the inside of the tank needs sealing. Probably a steering damper, a fork seal change, some seat brackets and then some good fiberglass strips to make a proper seat. It’s coming along. I’ll post a few pics I have taken along the way. I wish I had gotten a pic of what I found when I took the cover off over the sprocket. It was packed with chewing tobacco. Apparently the previous owner liked a chew, and so did the mice. I’ll try to keep it updated.
