Hey all, I recently replaced the low gear and kickstart in my CL175. Everything went back together just fine, kickstart is working great and carbs were cleaned and given new kits. The bike was able to start without a problem before I disasembled everything but after cleaning carbs and rebuilding them the bike will turn over but will not start without starting fluid. Spark is great, timing is spot on, battery is fresh, all seems to be normal except it just will not run. This must be a fuel delivery issue because all other factors are present, even great compression. I know this topic has been beaten into the ground on here but any ideas as to where I may be amiss? Thanks.
