I'm guessing that the seat that came with my basket case scrambler is a non-scrambler seat? When mounted, it hits the latch correctly but is off-center to the left by a solid 1.5 inches or so (see pic)?? If you look at it, you can see it is clearly the seat pan width that's the issue, it's not related to the seat material having moved to one side. Can't believe that Honda would design something this asymmetrical! (has to be the wrong seat right?)
Any thoughts?
Automotive tire Helmet Automotive design Shelf Motor vehicle
Tire Wheel Land vehicle Fuel tank Vehicle
72, K4 with side hinges correct?
Flip the spring loaded latch 180 ? It is offset.
I have had to repair every seat pan from every model that I have redone. Always have cracks, twists and bent in the middle from being used as a lift point to put the bike on the center stand.
Seat looks to be correct for the CL tank. CB would be way too short.
