The Saga continues on the CL450. FINALLY managed to get the head off. I found it useful to pot the pry bar as shown and gently wiggle it.
It seems like there most support is here between fins.
Upon getting it all apart, the cam lobes look ok.
Taking a look at the cam followers, things seem to be a little worse for the wear. The intake we slightly scalloped.
Looking at the exhaust side.. As expected, there is actually a lip on the outside edge, which can give the impression of proper valve gap.
A quick glance at the valves tells a little of the story. Looks like the one valve was just along for the ride, and the other side was definitely LEAN.
Good news, the cylinders don't look bad at all, there is even some of the cross hatching on them. It would seems that this bike was some sort of rebuilt, with a terrible valve adjustment.
The ends of the cams at least look pretty nice, I don't have anything to measure them, but it was a snug fit on the bearings.
On a good note, a local motorcycle group (G.A.S. located in greenville) member set me up with a sweet tank he happened upon at the dump, set out for trash. Yeah, it is FULL or varnish, and has some minor issues, but I think it will be a huge improvement over the tank the CL came with.
Original tank with metal welded in, dented badly, bondo falling off.
New tank, will require a very slight modification to the bike, but I believe will look sweet, and work well.
Thanks for keeping up with my build!
