Hi everyone. This is my first motorcycle and I am going to be changing out the rectifier today. I picked up the one from radioshack and am ready to start soldering. my question- im sure that the order matters on the rectifier should i just keep the same order as the original? and does it matter what post i start on on the rectifier?
thanks everyone!
YES!..... A rectifier is a "bridge" of diodes which ARE directional..... match your new rectifier's schematic (not its physical appearance) to the orientation shown on the Honda schematic ... ( hint: use the "arrows" in each diode as the flow direction) Think of all the "arrows' as pointing the "path" towards the red/white wire.........
all set! thank you for your help everything's soldered nice and heat shrinked. I have heard that a lot of people running these cb/ cls run without a voltage regulator do you recommend this?
Not unless you constantly check the battery fluid level, and don't mind replacing your battery more often.......Anything over the 14.2 volts the regulator limits the re-charging voltage to is likely to "cook" the battery...... I run the regs.....
i really appreciate your help. This is my first bike and it has been a learning process. I had just recently found this site (thank god!)..
Honda used the same regulator on 175's, 200's, 350's, 360's, and 450's, (twin cylinder bikes) so one should be easy to locate.... :D
