Hey everyone--
I hate to be that guy who only posts to ask questions... but here I am ;)
I'm having trouble diagnosing what is causing my bike to sputter out when I give it gas.
Here's a list of things I've already done (that would affect the issue):
Carbs cleaned, and rebuilt to stock specs
New stock air filters
New points + timing set
Valve adjustment
New spark plugs
It started right up after sitting for a year but would just putter out after a few minutes. I'm guessing it's a fuel/air problem? Or maybe with low compression? I tested it a year ago to be 140 and 135psi, left and right. I tested it again before I stared it today and I got 135 and 100! But I forgot to open the choke and throttle while doing it. I'm using fresh ethanol-free 91 gasoline.
Any ideas??
I did notice that it ran better when the choke was slightly closed.
It still died on its own after a few minutes or when I would try to roll the throttle a bit.
Update:
High idle problem solved. It was due to improper throttle cable adjustment at the carbs.
FINALLY seems to be running solid now!
I'm a happy man. :cool:
