Ear tab repairs
Although we have not posted much lately there has been plenty going on. I had bought a set of ear tabs along with a wiring harness from one of the members here. The ear tabs, although a little bent and having a few small holes in them were in fairly good shape and for the price were worth trying to restore to usable condition. The ones which were on the bike are candidates for a rust pile for sure as they were nearly completely destroyed by rust and not repairable.
I did not feel there was enough metal on the ear tabs to try to brazing the holes for repair, at least not with my limited brazing skills. I contemplated this repair for many days and finally decided JB Weld was the way to go. After using a small file to make sure I had clean metal to adhere to I used masking tape on the inside to keep the JB from pushing to far inside and worked it in a circular motion to make sure it was in good contact with the metal.
Here you can see the small holes. There were probably 4-6 holes in each of the pieces.
JB Weld worked into the holes.
After filing with a metal file I used a body filler to take care of any imperfections. Wet sanded and then sprayed on a primer coat. Both ear tabs turned out great. After three coats of primer with wet sanding between each they are prepped and ready for final paint. Color yet to be determined.
