My CB450 runs and idles great. The problem is from idle if you twist the throttle just slightly the bike starts to die. But if you blip the throttle it responds fine. It is almost not noticeable while riding it because you almost never open the throttle as small of a movement that this will happen at.
I have gone over synching the carbs a couple of times thinking that has to be it.
I am now suspecting carb pistons that might not be responding quick enough. I was going to try cleaning them up or maybe even polishing them some and their bores.
I suspect that I dont want to get too aggressive in polishing to keep the fit correct but what have others done with these to make sure that they are sliding smoothly, and do you think that I might be on the right track?
