1 - 2 of 2 Posts
I'm not familiar with the 450T's. I'm willing to give up some lower end grunt for better highway speed. What should I choose for sprockets / chain. I hope to be able to run 70 mph under normal use. Is this to much to ask of the 450? I don't think so. I've seen 14T to 17T front sprockets. Thanks for the help.
go with the 17T the 450 will pull it easy enough, think the rear sprocket is something like a 36 I've got a 34 tooth rear off a 360 with a 17 on mine to run 65/70 without it revving its gut out
1 - 2 of 2 Posts
