Hey gents. Here is my situation. Turn the gas on, and then gas comes out of the over flow tubes on the carbs, (more so the left one)
This happend out of the clear blue 2 days ago. bike ran fine before.
My diagnosis is the float is not rising in the bowl to turn the valve off in the carb.
I removed both carbs, inspected and cleaned them.
Reassembled, ran great! then they flooded again. Im very puzzled.
Any ideas?
Thanks for looking
-Dan
p.s. theyre keihin carbs if it helps
Any ideas?
Thanks for looking
-Dan
Did you check the "float height" when you had them apart?
height was fine. one of the floats had a hole in it. gonna solder it closed.
Holey Float Batman!....That would cause your symptoms..... :lol: :lol: :lol:
haha indeed, bought a mini torch from harbor break, and some solder ..worked good. everyone keep your fingers crossed, i need this bike running, i told a girl id take her for a ride haha. thanks guys
-dan
Got it running, took it on the hiway 65mph tops, when i came off the was a good deal of smoke coming from the right tail pipe.
The exhaust felt cold when holding your palm to it, and comparing it to the left pipe.
Im assuming for now it is a fuel issue, but not sure. Any ideas
Thanks
-Dan
