This is my first motorcycle engine rebuild and I'm being as cautious as my mind will allow. I've got several questions and I apologize but I didn't want to make eleventeen different threads.
1. Is it worth upgrading the charging system with an CB200 generator? I will be upgrading to the Charlie's Place electronic ignition and regulator/rectifier
https://www.charlies-place.com/shop...9-cbcl160s-68-73-cbclsl17-and-74-76-cbcl200s/
https://www.charlies-place.com/shop/type-1-regulatorrectifier-applications/
2. I'm replacing the oil pump no matter what so would an CB200 oil pump fit and would it be advantageous to fit one to my engine for better top end oiling
3. How do I gauge the the wear on my clutch discs? They look quite good to me but I have no problem replacing if necessary.
4. Should I replace the rocker arms and valve springs?
5. The rings gapped at .006" which is the minimum allowable. Do the rings on motorcycles typically need no filing or do they come good to go? Not having to file the rings goes against what I've read and seen on YouTube videos. What gives?
6. Is there anything I need to watch out for more so than anything else?
This is the new cam chain tensioner that I got today. Has anyone else used this set?
