After taking off my rear sprocket for my Cl350 I found that they are very badly cross-threaded and was wondering if I could use the one found on the SL350 as they look almost 1:1 but I'm not totally sure
Administrator
If it's the same length, width and pitch it will work - however, what do the threads look like in the hub? That could be a problem.
There are NO threads in the hub....The ends of the sprocket bolts that fit into the cushions are smooth unthreaded pins....
Administrator
66Sprint is right - those aren't regular bolts - sorry about that
CMSNL.com shows different part #'s for CL350 and SL350 sprocket bolts so I would guess they are not interchangeable.
