Hey all,
I've been trying to work out some kinks on my CL350 for the past couple weeks now. I bought the bike with aftermarket exhaust but got a sweet deal on some stock CL pipes, so I mounted those up and had the carbs rejetted at a local shop. The bike has cheap pods, which I know can be problematic but finding stock air boxes would be out of budget. After problems under load, I took the bike back and had them jet it again and if seemed to run very well so long as I left the choke open. With it closed, it would struggle to idle then bog under load. I took the bike for a couple short rides and didn't have any issues, it seemed very strong. Unfortunately that night I left the ignition on and drained the battery. The next day I charged the battery for about 2 hours, and went on a longer ride. The bike started to crackle and pop, then started to lose power and bog before sputtering and dying. I had to bring it home in a truck. Since then I have checked the plugs (they both spark, the left one was covered in soot so I replaced that) and recharged the battery fully. I thought the issue might be bad gas since I hadn't run through a tank in about 6 weeks, so I drained the tank and the carbs, put in a new filter, and added new gas with stabilizer/carb cleaner. The old gas was a bit cloudy and hadn't beed stabilized. The bike still won't run with the electric or kick start, even though the battery seems to hold a charge. I'm not sure what else to check at this point, but I'm hoping there are a few more things to try before I take it back to the shop, any help is appreciated!
Bonus pic of the bike:
