When I took apart the bike the fuel lines were dry rotted or something nasty because they literally disintegrated. I can't find new ones. Do they have to be specifically for the CL or does CB SL XL fuel lines work and where can I get a full set?
Your local auto parts store will have fuel line or a local motorcycle shop. Stay away from vinyl line as it hardens over time. Stick with rubber or Tygon. MotionPro has fuel line at reasonable prices if you must shop online..
Your local Honda shop will have some as well and it's pretty reasonable. I've gotten stuff at the auto parts store before and it's usually vacuum tubing they sell and it has the thicker walls and doesn't like to shape and bend as well. Additionally, it's usually 1/4" tubing and I think you need either 5mm or 5.5mm, I forget which.
