Hi
I read a number of posts on how to drill out the stake (I used 1/8" bit) in the aluminum bearing retainer screw, worked out well and the large retainer came out easily using the special Motion Pro tool others have referred to. Question I have is how to re-stake the retainer? Do you just punch the drilled hole or start another? Do you fill the hole with something soft metal, then punch that? I was thinking of just filling the drilled hole with JB Weld which can always be drilled out again in the future.
Thanks
Tony
Thanks
Tony
