1 - 2 of 2 Posts
Recently the clutch/trans has been giving me a problem. I can't get the bike into first gear anymore. It worked and then stopped. It is the clutch? all the other gears are working ok. I have messed with the adjustment barrel on the clutch lever. Every now and again I can get it into 1st, but it is sort of clunky.
Any ideas on this.
Thanks.
Does the bike still give you trouble going into gear with the engine off? If it does you might have a trans problem...bad labrynths on the drum, bent fork, cant say for sure. hope this helps
-dan
1 - 2 of 2 Posts
