Hi everyone-
I have a '71 cb350 that I've been working on/struggling with. Right now, I can get it started up but it will only run for 3-5 minutes at between 2-4K RPM idle. It will wander around between 2 and 4K seemingly at random, wind up to about 4-5K and then die (see video below). Here is some recent work that I have done:
1: cleaned fuel tank (metal rescue + mystery oil, looks pretty good and petcock is clean after running a bit of gas through)
2: cleaned petcock (after fuel tank clean)
3: cleaned/rebuilt carburetors, set float heights to 25mm (replaced jets/needles/gaskets with these kits from CM Honda CL350 Scrambler / CB350 Carburetor Rebuild Kit |Common Motor Collective)
4: inspected carb diaphragms (replaced 1 b/c of tear)
5: new battery (kept on tender when not on bike)
6: new fuel lines
7: bench sync'd carbs
8: new throttle cable, sync'd with carbs
9: new spark plugs + boots
10: replaced regulator/rectifier (Rectifier / Regulator Honda CB350 / CB360 / CB450 / CB500T | Common Motor Collective)
I have yet to check the timing; PO installed PAMCO ignition and I do not own a test light. Both cylinders are firing, however, the left side has stronger exhaust flow.
Any ideas as to why the idle is so high/why it will only run for 3-5 minutes, then die?
Go get yourself a proper timing light(30-40$) so you can properly set the timing. It will be cheaper,in the long run, than just throwing new parts at it.
Float spec is 26 mm with carb held at angle with float just touching needle valve. I set floats to at least 26.5 mm and even up to 27.
Check your throttle cables for slack and the clamps at the manifolds for alignment and tightness. I put the clamps close to the edge of the manifold, towards the carb. Turn your idle mixture screw 1 and 1/8 turn out. Adjust your throttle screws a small amount at a time, CV carbs respond a little slower.
