Will these parts from a '71K3 fit my '73G CB350?
starter
coils
carbs - '71 is a "TL 3D(?)" and'73 is a 722A
motor parts
Gas tank
Also, Is there an interchange manual for 350's?
Thanks,
Larry
AFAIK, everything you asked about will swap with the possible exception of some carb parts... The entire carbs (as a pair of units) should work ...I believe the major differences in the two bikes were seat, handrail (or not), front brakes and associated parts, and the front forks and trees... (again, these should mostly swap as units, except the seat as I believe the hinge and lock positions changed)
