Status
Not open for further replies.
2days 20hrs left when post here 6bids $202.50
http://cgi.ebay.com/ebaymotors/Vintage- ... 240%3A1318
this from posting
I have never started, or attempted to start, this bike. It turns over fine, has good compression, and shifts through all of the gears. As you can see, it has no front end. Again, I repeat, this bike has no front end at all!! The owner said that he had removed it to put onto another bike (these are readily found on Ebay). This chassis sits nicely on a block of wood. This bike is also missing the carbs, and probably some other miscellaneous minor items. The bike still has the headlight and wiring, as well as the horn, ignition switch and key. The rear tire is like new, and looks to be correct OEM, but not the actual original tire. This bike has some surface rust, but is basically dent free. The exhaust has some surface rust, but will clean up decently. The inside of the gas tank has some light rust, and old gas crud, and will need cleaned.
I have been watching that one as well. I need the exhaust. Are you looking at it to restore it?
I'm not looking at it at all passing along what looked like a good deal
Ernie
Status
