Rearsets that wont set you back!
I had seen a set that someone made on a diff site (
http://dotheton.com/index.php?topic=7401.0) and decided to make my own set. I absolutely hate working with aluminum and I wanted to go with something that had a lot more strength.
i picked up a 9x 15 sheet of 3/16" steel for $10. (enough steel to make 10 of these)
the pegs were $20 at a local bike store ... Really high quality. could have made my own but wanted to save some time
bearings were 5 bucks for the both of them
Axel bolts $3
these only took me about 3 hours to make. the most time consuming part was cutting the steel.
I made templates in Autodesk Inventor and spray glued them right onto steel. than i center punched my holes and began cutting.
i spec'd out the bearing with a dial caliper and than heated the steel to allow the bearing a real tight fit. let it cool down gently dont want to flash cool it.
