First off, hello, I'm Glen, I'm a Ducati addict, started with VWs and that was just a gateway.. My addiction has taken a lot of money and ruined relationships, I figured I should move onto a more affordable habit...In anycase, I've taken on the project of figuring out what the issue is with my friend's CL 350. First thing Id was a compression check, as it feels it's running on one Cylinder. 60, 60, 60, 60.... other cylinder, 135,135,135,135...This is a stock bike with 12k on the clock. Of note is white smoke out of the low comp cylinder (the left if that's of importance).
What are the next steps I should address?
Is this generally a head/valve issue? Cylinders/pistons/rings? Any input would be welcomed! Thanks a ton.
Glen, I assume the measurements were made hot with the throttle wide open....
If so, the top end needs rebuilt...... 170 is the normal compression with a 15 PSI maximum variance... It needed re-ringed at 155....
Wellll, the motor was hot but no WOT... just cranking over until the max reading was reached. Re-ringing isn't out of the realm of what I Imagined was the issue in anycase. Tomorrow I'll try WOT after warming up, although in either case, it'll be that one cylinder is totally lacking.
After further reading tonight I learned to put some oil into the cylinder to find if it was rings or valves. I'll also try that.
I forgot to mention in my initial post that the suspect cylinder was blowing baby blue smoke...
Baby blue huh?..... Ya think any oil is getting past the worn rings?....LOL....
It won't hurt to add oil and ascertain if there is also a valve problem, although that might not be readily apparent with such low compression......... I'd just tear it down now, physically check/measure each component, and order what I needed to put it back to specs.....
It could be a blown head gasket too. Are you getting visible smoke out of the breather when it's running?
That's the problem I had when I recently pulled the head off my 450. Either way, it's going to have to come apart.
