Start by checking the battery voltage with and without the motor running. Make sure the battery is good. These bikes will not run well on a weak battery. With the engine off the voltage should be around 12.6 volts. With it running it should be around 13.6 at higher engine speeds. Do a search for charging. There are a lot of info on this subject. Let us know how it goes.
