I have a 1968 CB450 K1, which apparently sometime in the long past, someone put on extended forks. I haven't measured them but they are at least a foot longer than regular forks, possibly more. Are these worth anything to anyone or should I just chop them down to the size that I want them and not feel bad that they were made 30 years ago? Or should I post to see if anyone wants to swap these?
Also, where (if anywhere) can I get replacement rubber inserts for the isolators for the tripple trees? The rubber bushings that are inside where the handebars go through?
Bird76Mojo said:
Somehow I knew someone would know that... That's why I thought the ones I posted were a little pricey..
Good call..
Woops - my bad !!!
I see we're talking about a K1, those parts are NOT available anymore - sorry.
However you could conceivably swap out the entire front end with a disk brake model if you were so inclined. The frame is the same, but the K1/K2 top clamp and forks are NOT the same.
I have a CB360 front end with a disk brake, which I like. But this funky double spring front end sort of has my heart. There is a guy already selling some 12" over forks on e-bay but they don't seem to have moved quickly, which is why I was wondering if I should just chop the forks down and be done with it. But I hate to destroy things because once you do, you can't put it back together.
It's probably unlikely that you could shorten those tubes successfully.
And though they may have captured your heart, they're probably among the worst forks ever made - you haven't ridden on them yet..
I had a pair of K2's - same forks as yours.
The only good thing I can say about them is that they're replaceable..
You could directly swap that entire 360 front end, stem/triple clamp/forks/fender/brake/wheel, the whole thing as a bolt-up.
It would look better and work WAY better.
