1 - 1 of 1 Posts
Cb 360 idles on right cylinder but will rev out and run on both fine when above 2000 rpms, compression is 150 in both cylinders new intake boots and gaskets valves set and timing, cleaned carbs all jets compressed air , carb cleaner guitar strings several times, switched coils around no change in left side idle air fuel screw makes no difference on left side no vacuum leaks showing when sprayed starter fluid going to recheck timing but kinda at a loss , float levels at 22mm and checked with clear tubes and are just little below the top of the bowl, looking for any advice or ideas, had all new jets in the carbs but plugs showed little rich black and sooty , cleaned oem jets and installed and set float heights 20mm not sure witch way to go
1 - 1 of 1 Posts
