ok got my 360 swingarm off my donor frame, swingarm bolt/swingarm has no grease zerk fittings so going to put a zerk into the arm itself, can the 450 pivot bolt be use also? can't find my digital caliphers are the pivot bolts the same dia.? still haven't decided on if I going with modding axle dia. on the 360 arm or just using 360 wheel,
Jayel...The pivot bolts should just interchange if you want the additional zerks..... The 360 arm should have a zerk on the underside if I remember correctly.....
well got my 360 swingarm mounted on the 450 amazing what that 2"ish strecth does to it, sits a little lower, (bottom shock mounts are farther back), changed the shock angle, no difference between the 360 and 450 shocks that I could see, had to trim about 1-1/4 off the front of the 360 chain guard (longer and sits higher, runs right into sprocket cover) ride is different, doesn't have that short-coupled rocking horse action as much as it did, all in all this was a + as a upgrade, had to add 3 blocks to the chain (5 links) , hardest thing was widening axle slot (I love my Dremel) and 4" grinder,
