Hi folks
Has anyone tried to install a cb450 crank in a cb350 bottom end?I am in the process now I have the crank with the correct bearings and crankshaft works is going to install bushings in the small end of the rods to except 15mm wrist pins plus lighten and balance the crank.
This is a learning curve for me just wondered if anyone has done it before and knows of any problems.
Also JE Pistons is making some 73.5 mm pistons like the old Powroll pistons sleeves are coming from LA Sleeve.
Using a Mega Cycle x 125 cam 1mm larger valves and beehive springs 34 mm flat slides.
Any ideas?
Any ideas?
