Can't remember exactly who it was that was trying to use 450 carbs on a 350.
Here's a bit of info that may help renew your interest.
As I recall, the problem was that the carbs ended up running into the frame tube??
I was just in the shop and discovered that the CB400 Twin carb manifolds (from the later SOHC twins) fit nicely on the older 450 DOHC carbs, and they have a slight "angle" or tilt to them, which may be enough to allow them to clear your 350 frame downtube. Probably the same part as the 450 SOHC twins and Hawks, too.
