Thanks, but before i go to this level. Can the stock brake be made to work good enough compared to say the stock drum model. I found parts to fix the Stock mechanical one for $80 . or should i just put that money to the conversion. Mind you im not looking to make this thing a rocket so id be happy with what im used to coming from drum brakes. Basically is the Mechanical drum brake worth a darn.
