Is this the same scenario that can be solved with a 1" ID washer with holes drilled in it?The problem that is going to take place is the chain alignment. The CB450SC front sprocket is 4.2mm's out board of the CM450E and CM400E. This can be corrected by getting a offset sprocket from some one like PBI. It's not possible to space the rear sprocket out due to the design of the wheel
Good catch, I had a senior moment on this one. The washer will work nicelyIs this the same scenario that can be solved with a 1" ID washer with holes drilled in it?
