Hey all,
So today when commuting home on my 1983 CM450A I got about a block from the office when there was a nasty crunch sound, I lost all power, and I felt something grinding somewhere along the bike's drivetrain.
I pulled over immediately and found that the chain looked like it was off the front sprocket. I thought the chain had broken but when I pulled the side cover off I found that the chain was intact but the front sprocket was totally gone.
I searched all over and around the road where it occurred but couldn't find the sprocket or any other parts anywhere so I'm not exactly sure what failed or why.
Inspecting the end of the countershaft and the rest of the area where the sprocket lives doesn't show a whole lot of damage.... There are two big gouges that were scraped along the side of the case where it looks like the chain dug in when the sprocket failed but neither of them touch the countershaft or the oil seal surrounding it. The bottom edge of the case housing was cracked off where the sprocket undoubtedly smacked into it when it let go and the grease nipple for the swing arm bushing got snapped off. Here's a picture I snapped of the damage:
There's a bunch of grease in and around the swingarm bushing and a fair amount of chain lube that has gunked up the area but I don't see any evidence of oil leaking from the countershaft seal.
Both the chain and the sprocket were essentially brand new, having been replaced less than 500 miles ago and until today had no problems at all. I went on a ~150mile ride yesterday with no problems at all (really happy it waited until today to let go, not yesterday 100 miles from home!) though I've got to think that that ride definitely contributed to the failure since my daily commute is less than 10 miles and I rarely get the bike over 40 along the way.
As to why it failed, I'm guessing that either the retaining bolts for the sprocket plate were way out of spec and torqued themselves loose enough to come right out... or the chain tension or alignment was way off which wore down the same bolts to the point of failure.
So, going forward I'd love some input on what else I should check out for damage. I have a replacement sprocket on hand and ordered a new retaining plate and bolts. Will replacing those be enough to let me ride safely? I'm going to remove and thoroughly inspect the chain but barring finding any obvious problems is it crazy to reuse it? From the point of failure to being pulled over at a dead stop I traveled only 30 yards or so so I'm hoping the chain didn't get much abuse in that short of a distance, especially since its practically brand new...
Am I missing anything here?
Thanks for any advice, it is appreciated as always!
-Joe
-Joe
