1 - 16 of 16 Posts
You have my attention but it looks like the link is broken. Im looking for a cm450 engine (or a cm400 head/valevtrain if you have one lying around)
Does the VT in your name stand for Vermont? If so, I'm not too far away!
Ok, I'll check the link, thanks. Yes, I'm in Rockingham, Vt and I do have some cm400 engine(s). michel
Ah, I tried opening it with chrome (I usually use firefox) and it worked. I suppose I should have tried that before making a fuss.
It looks like you've got quite the collection, and Rockingham is only a couple hours away, not too bad. I'd be interested in one of those engines, Ill send you a DM
Hi there; looking for 1 or 2 carb insulators for my 1983 cm450a. Apparently these only fit this hondamatic model. Would have MC1 embossed on insulators outer surface.
Please respond if you have one. Cheers... Thorinn
Hi, Oldguysrule, seeing as you're in Canada I will make an exception to my rule # 1 which is:" Never sell to someone with less than 20 posts."
send my your email address & I'll send you some pictures of both (sold as a pair because they Might be different left/right and an offer.
sincerely,
michel
PS My son is getting married tomorrow so it will probably not be able to get them off until monday/tuesday. Hope you understand.
1 - 16 of 16 Posts
