Okay so the problem is that neither of the front turn signals will light up at all. Previously both worked fine and flashed properly. The rear come on but do not flash. I have unplugged both and plugged them both in and one did flash for a moment, until the flasher wound up and clicked rapidly then turned off. Now neither will light up at all and I'm stuck. I would appreciate any help. Thank You for the view
Clean and tighten all the wire connections and clean the sockets and bulbs.
Ok so I cleaned and tightened everything and switched on left blinker, flasher spun up quickly but it still did not light up. I then retried and flasher made no noise but a single click. Do the front have a separate fuse? I'm just not sure quite what's causing them to not have power all other lights and indicators are all on strong
I'd say the next, easiest step is to get a new flasher and see if it solves the problem. I had issues with my signals as well and a new flasher fixed my problems.
