This is Nebula; I began a project log in my introduction thread: http://www.hondatwins.net/forums/23-member-introductions/98681-nebula-1980-cm400t.html
The photograph above is where the bike stands at this point. I'm making my way toward a "Brat" style with some personal mods (a slightly less flat seat, because I'm reshaping my own, etc.).
My log, updated:
What I need to do:
Carb synch
Compression tests (it seems fine, just want to know)
New rear shocks
Install new carb jets/shims so I don't need to have a t-shirt mod on the pods ��
Install new spacer in rear wheel
New tires (possibly new rear wheel... subject of a later post/video)
What I want to do:
Reshape the seat
Leather grips
Rewire all the wiring under the seat
Buy/Install anti-grav battery
Paint the tank custom matte black nebula base
Chop rear fender
Blackout fenders
New exhaust tips
What I've done:
Gone through most of the checklist on the new-to-me thread
Replaced the battery
Cleaned the wiring/rewired some areas
Stripped the bike of fenders, heat shields, reflectors
Rebuilt the carbs, about 4 times
Replaced the handlebars with zero drag ones
Moved the lighting around to some temp positions until I save up and buy the ones I want
Wrapped the pipes
Oil change
Replace air filter
Got my M license
Registered/plated the bike
Bled and refilled the brakes
Degreased a metric ****-ton of old grease
Placed a new taillight and license plate
Found the source of a voltage leak (bad wiring)
Reworked the stock controls; they work like new
Got the carbs to stop leaking
Installed pods (I know. I've read the threads.)
Rode
