Got this bike in October from a PO who bought it and let it sit for about 7 years. Changed out battery and spark plugs, and replaced fuses; removed carbs and cleaned all jets, etc, (and replaced gaskets and diaphragms); replaced throttle cables (push cable was broken). I have power and spark and she runs! With thanks to some folks here in this forum who guided me in peeking under the cam cover to make sure things wouldn’t get ruined if I turned it over. I still have some fuel delivery issues (I know, that’s a different topic category)- I think the tank is pretty gunked up even after a clean out, so I’ve had to flush out the inline fuel filter. But I can get her to run, “hands free” though sometimes need to adjust the choke to keep it running. I have no front brake right now, so I’m not going anywhere yet.
And here’s my question: with the bike running, I pulled in the clutch and tapped it into first gear, and it lurched and stalled. So now I’m looking into the clutch - got the Right crankcase cover off and took off the lifter plate and springs, and it feels a bit like all the plates are stuck together. I can separate them with my fingers with a little effort, but should they be more freely and easily moveable individually?
im thinking they could use a little looking after, and a good soak, and if so, I have that locknut to contend with, but I won’t bother if you tell me the clutch plates seem fine.
thanks in advance for looking!
can’t seem to attach video here so
I posted a video to YouTube showing the clutch plates:
