I'm at a loss.
So 2 weeks my front blinkers just weren't working/have the weakest signal. So I replaced both bulbs and stilll nothing. I took the head light casing off and then one the nuts on the right side that was holding in a ground fell off so I just tightened it back on thinking it would fix the issue. It did not. Figuring the ground was bad, I rigged up a new ground with a ring and placed it behind the nut and I don't think that was the issue at all. What's happening at this point is that when I have no bulbs in the front both of the back just stay on in each direction. When I plug a bulb in the relay will start blinking and the turn signal light on the bike goes but none of the lights work. I've checked all the connections and they're right, I even cleaned all the grounds but I don't know if I'm missing something. All blinkers were working 2 weeks ago and now I don't know what to do.
