Hope i can explain this well but my bike seems to jump from 2nd gear into 3rd and sometimes in will try to go back into 2nd and just makes the bike jerk back and forth. This doesn't happen all the time and the odd time i think it does it from 3rd to 4th.Is there any ideas on what i should take a look at? When it is not doing this the bike seems to shift just fine.
Detent roller and spring problem ?
Have you had this bike for sometime or is it a recent purchase ?
You know of CMSNL.com for the exploded views ?
You have the clutch nut peg spanner ?
I am assuming the gear change foot pedal is correctly set, the small arm on the gear shaft set vertical ?
Oil change, any glitter in the oil ?
The dogs of the gears may be worn, they should have a slight " dove tail" so they "lock" and remain "in gear", but if worn they can jump out of gear.
Picture of the gear pedal is a good starting point.
