Does anyone know the float setting for a 78' Twinstar? When I first got it put fuel in the tank and it puked out of the overflow tube. I tore it apart and hooked a hose up to it and started blowing air into it while moving the float. I have it set right now to where the needle seats right when the float is level with the bottom of the carb body. I'm only asking because as of right now the bike will only start with starting fluid and when I have my idle set high. I was planning on tearing the carb apart and soaking it and would like to know the proper adjustment for the float. It has a Keihin on it right now. Thanks
