Folks I couldn't wait for the weekend to get back at my carb. I am going to be a little more careful with my cleaning. I did fine the size of the jets stamped on the jets so I shouldn't have a problem putting back into the right spot after they soak in the cleaner for a while. the part I am not sure about is the "slow jet plugs" as stated in an earlier thread I completed soaked them when I made my first attempt at cleaning the carb. they seemed to deteriorate to a certain degree. The manual indicates that "they can not be removed since it is a tight press fit" I have attached a couple of pictures 1 of all I took apart, the second is of the "slow jet plug" any comment would be appreciated.
Thanks
Bear1959
1978 CB400T ii
Thanks
Bear1959
1978 CB400T ii
