Bought this bike a few months ago as a project. Didn't run when I got it and still doesn't now but I've been working away at it. It's been issue after issue but it's been a good learning experience (my first big overhaul).
The bike as seen in the ad:
With the seat:
Tore it apart:
I cleaned up the frame, wheels, etc. Lots of caked on gunk from sitting around for years. Trimmed the seat down - thought it looked too bulky before and the cover was already torn and half replaced anyway.
I cleaned up and rejetted the carburetors although they aren't spotless so I might have another go. Like I said, the bike sat for a long time. Cleaned the oil filter, replaced a broken gear (oil pump drive gear I believe), cleaned out the gas tank.
Had some trouble with the wiring - at some point in time someone spliced some wires and cut some others. Sparks fairly well now.
This is how the bike sat yesterday:
I couldn't get it started so I did a compression test, only 65 and 75 psi..... Opened up the top end today and found that a couple of the piston rings were jammed into their slots, I managed to get all but one unjammed but I can't get the last one. Anybody have a trick for this?
With the seat:
Tore it apart:
